It is currently Sat Sep 13, 2025 10:14 pm
 Post subject: Heat blanket for Uke
PostPosted: Sat Jul 25, 2020 2:36 pm
First name: David
Last Name: Scheckman
City: Plainfield
State: VT
Zip/Postal Code: 05667
Hi, Is there any reason not to use a guitar sized heat blanket and fox style bender for bending Uke sides and bindings? I’ve made a couple of guitars and have the bender, slats and blankets. Seems like it would work fine as long as I build the mold the fit. Thanks for any insight.
David
PostPosted: Sat Jul 25, 2020 8:52 pm
First name: Brad
Last Name: Combs
It could work, but the challenge might be the overall length of the mold may not extend out past the walls of your guitar bender. I purchased the uke sized bender from blues creek, it works well. The walls of the bender are smaller so the mold sticks out each end.
Brad
 Post subject: Re: Heat blanket for Uke
PostPosted: Tue Jul 28, 2020 12:09 pm
That's what I've done. The mold needs to be taller, not only to clear the bouts but also because since it's on rails, you need to have room for the blanket to bend and come out.
These users thanked the author Pmaj7 for the post: bcombs510 (Tue Jul 28, 2020 2:16 pm)
